Re: Tomos - add an AC regulator b4 rectifier?
Seth Zaiser /
Ok, so you have the battery grounded and the stator is putting out voltage. Check the amperage across the battery terminals with the bike running and all of the lights off. Be careful not to blow the fuse in your meter. Most will blow over 10 amps, but I doubt you're putting out that much. If you get anything, you're charging the battery. If you get no amps across the battery, be sure that the positive and negative from the battery and the two leads from the coil are connected to the rectifier in the right positions. If everything is hooked up right, check the four diodes in the regulator.
  Tomos - add an AC regulator b4 rectifier?Topic by: Chris Davis Chris Davis 06/06/12 07:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 09:25PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/06/12 10:31PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Weak-Ends Tj Weak-Ends Tj 06/06/12 09:30PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 02:53AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Steve Mertz Steve Mertz 06/06/12 10:51PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:54PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 01:16AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:17AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:30AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 08:48AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 09:27AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: John Warren IhazJawas John Warren IhazJawas 06/07/12 10:29AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 01:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 02:03PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 02:10PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 07:16PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 07:24PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/08/12 12:09PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/08/12 12:34PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 09:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 10:15PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/09/12 01:37AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/09/12 01:57AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/09/12 01:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 04:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 05:04AM
