Re: Tomos - add an AC regulator b4 rectifier?
Chris Davis /
Seth Zaiser Wrote:
> Pardon my lack of tomos knowledge, but all tomoses
> I know already have a regulator and the light are
> AC. Unless you're adding a battery, you don't
> need a rectifier, and mopeds that do have
> batteries are half wave rectified (aka just a
> diode).
I know it has a "regulator" but what it regulates is the amount of a.c. Watts it lets thru, not the voltage. (at least that is what I've been told)
LEDs need a pretty stable voltage or they will die very quickly.
there's nothing stopping me from isolating tomos regulator from the frame (its currently set to go to the lights) and hooking the output of it to a bridge rectifier to convert it to dc (or use the regulator/rectifier). Then hook the minus to the frame and the plus to the wiring harness.. Then you should be able to add a battery so your lights won't dim anymore.
  Tomos - add an AC regulator b4 rectifier?Topic by: Chris Davis Chris Davis 06/06/12 07:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 09:25PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/06/12 10:31PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Weak-Ends Tj Weak-Ends Tj 06/06/12 09:30PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 02:53AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Steve Mertz Steve Mertz 06/06/12 10:51PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:54PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 01:16AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:17AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:30AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 08:48AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 09:27AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: John Warren IhazJawas John Warren IhazJawas 06/07/12 10:29AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 01:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 02:03PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 02:10PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 07:16PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 07:24PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/08/12 12:09PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/08/12 12:34PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 09:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 10:15PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/09/12 01:37AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/09/12 01:57AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/09/12 01:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 04:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 05:04AM
