Tomos - add an AC regulator b4 rectifier?
Chris Davis /
trail tech.net
has a a.c. Regulator that regulates the a.c. Voltage to a stable 13.8 volts.
This would then then be rectified by the tomos rectifier and we'd had have a pretty stable power situation, right? Would it be good enough to switch to LEDs?
trailtech.net/regulator.html
they also have a regulator/rectifier that looks like it could be used to replace the tomos regulator and and maybe let us add a battery.
  Tomos - add an AC regulator b4 rectifier?Topic by: Chris Davis Chris Davis 06/06/12 07:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 09:25PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/06/12 10:31PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Weak-Ends Tj Weak-Ends Tj 06/06/12 09:30PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 02:53AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Steve Mertz Steve Mertz 06/06/12 10:51PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:54PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/06/12 11:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 01:16AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:17AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 03:30AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 08:48AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 09:27AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: John Warren IhazJawas John Warren IhazJawas 06/07/12 10:29AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 01:58PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Jake Syrek Jake Syrek 06/07/12 02:03PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Seth Zaiser Seth Zaiser 06/07/12 02:10PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/07/12 07:16PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/07/12 07:24PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/08/12 12:09PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/08/12 12:34PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 09:18PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/08/12 10:15PM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Goose . Goose . 06/09/12 01:37AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/09/12 01:57AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Totally normal JBOT Totally normal JBOT 06/09/12 01:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 04:55AM
  Re: Tomos - add an AC regulator b4 rectifier?Re: Chris Davis Chris Davis 06/10/12 05:04AM
