Re: Yes sir offficer, the pedals work... yes sir... only 49cc.
Saabsonettguy . /
Many of the race engines had drilled valve pockets or were drilled at the very bottom of the cylinder. It was probably a simple way to get as much exhaust flow as possible, and obviously sound wasn't an issue. You can see the ported cylinder base in this video.
  Yes sir offficer, the pedals work... yes sir... only 49cc.Topic by: Brad William Brad William 06/03/12 11:25AM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: matt v matt v 06/03/12 11:29AM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Brad William Brad William 06/03/12 11:31AM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: nj dan nj dan 06/03/12 12:13PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Brad William Brad William 06/03/12 11:40AM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: greg kohler greg kohler 06/03/12 11:52AM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Flagrant - Flagrant - 06/03/12 12:06PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Josh Cranston Josh Cranston 06/03/12 12:10PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Rich (OFMC) Rich (OFMC) 06/03/12 12:11PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: CtpEDsHED . CtpEDsHED . 06/03/12 12:21PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Cosmo nPuch Stillstolen Cosmo nPuch Stillstolen 06/03/12 12:29PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Saabsonettguy . Saabsonettguy . 06/03/12 01:18PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Kevin Carl Kevin Carl 06/03/12 01:34PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: brian foss brian foss 06/03/12 02:18PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Rollo Tomassi Rollo Tomassi 06/03/12 03:07PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Cosmo nPuch Stillstolen Cosmo nPuch Stillstolen 06/03/12 09:09PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Pizza the Hutt Pizza the Hutt 06/03/12 08:58PM
  Re: Yes sir offficer, the pedals work... yes sir... only 49cc.Re: Cameron Acuff Cameron Acuff 06/03/12 09:05PM
