Largest tire to fit 1977 motobecane 50v moped
What's the largest tire to fit 1977 Motobecane 50v moped.
I believe a 2.25-17 is a stock size for both front and rear.
What's the biggest that will fit both front and rear without
removing or changing anything.
Re: Largest tire to fit 1977 motobecane 50v moped
2.50
Indeed 2.5-17 is the biggest without mods
I put 2.5x17 on my 50vlx
Bruce Zapper /
My VLX Stock 2.50
2.5 will work with precise alignment.
Dan (LandLordsMG/PSVMC) /
How much more clearance is needed for a 2.75?
You have to offset your sprocket on the rear or the chain will make XXXXXXX pattern on the sidewall of the tire and it will rupture with zero warning.
thanks rebel, im almost up for the challenge just for the sake of it
