Re: tomos 5 stars
Daniel '' /
Should be an easy bolt on. I do believe that the TOMOS sealed bearings will press right in if you take the old cups out. But unless you have the later model hydraulic forks that needs a sealed front you wont have to do too much work to make them fit.
