tomos 5 stars
Arnie Sparaco /
will tomos 5 stars for a a3 tomos bullet work on a 2005 a35 tomos??
Re: tomos 5 stars
any wheel will work, those may be closer to where you want to be, but you almost always need to space and shim, also a3 mags are loose ball, might as well convert to sealed bearing , then you can use all your 2005 rim bits.
Re: tomos 5 stars
Should be an easy bolt on. I do believe that the TOMOS sealed bearings will press right in if you take the old cups out. But unless you have the later model hydraulic forks that needs a sealed front you wont have to do too much work to make them fit.
