Re: cheap Kinetic project, bad idea?
Maciek Dub /
Okay, so I re-skimmed the thread, sorry just skimmed to the end at work b4. Sounds like you basically scored a half a grand worth of ped and parts that someone did kind of messed up, trying to fix the original problem with parts maybe. Basically what I was running for a while. I'm almost positive the above combustion chamber to exhaust leak is your problem, unless you backed the plug out for that pic. basically your charge gets pushed out that hole to the exhaust port and maybe even back in the case when it ignites. Get a decomp valve and spring, i think you can get malossi ones from the shops even, might as well get a cable and hook it up to the lever, will make it much easier to start, it will be hard to start with a kit once the compression is fixed. also coil should be grounded to the frame/motor but sounds like you did that already.
While you have the case apart might as well port match it to the kit, even an easy mild match with a file will help a lot, cause that kit mostly breathes through the piston anyway, and do the inlet to 13mm, gently and carefully, i've fucked a case up as well as many others, and you don't want to be waiting for another set. grab a roller crank if you can afford, slap it together, and you'll have a solid traffic worthy ped, even the jetting may be about right. Here's an old vid of smitty's matching that kit
http://video.google.com/videoplay?docid=-100389612806311947
till the subframe cracks that is. where mine cracked, and weakest part imo to reinforce is all those holes around the carb, i'm thinking easiest thing to do is weld a plate or something over them and just drill the hole you need to access the clamp screw.
gl!
m (edited)
  cheap Kinetic project, bad idea?Topic by: preeesh . preeesh . 05/30/12 03:58PM
  Re: cheap Kinetic project, bad idea?Re: Don Sumpter (OFMC) Don Sumpter (OFMC) 05/30/12 04:08PM
  Re: cheap Kinetic project, bad idea?Re: Saabsonettguy . Saabsonettguy . 05/30/12 04:20PM
  Re: cheap Kinetic project, bad idea?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 05/30/12 06:22PM
  Re: cheap Kinetic project, bad idea?Re: Jimbo Grand Daddy Jimbo Grand Daddy 05/30/12 06:49PM
  Re: cheap Kinetic project, bad idea?Re: Woot Senpai Woot Senpai 05/31/12 11:37AM
  Re: cheap Kinetic project, bad idea?Re: Rick Ems Rick Ems 05/31/12 01:22AM
  Re: cheap Kinetic project, bad idea?Re: Stephen Keller Stephen Keller 05/31/12 01:31AM
  Re: cheap Kinetic project, bad idea?Re: mit mortso mit mortso 05/31/12 01:43AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 05/31/12 02:38PM
  Re: cheap Kinetic project, bad idea?Re: John Kiniston John Kiniston 06/01/12 08:32PM
  Re: cheap Kinetic project, bad idea?Re: felix the cat felix the cat 06/01/12 09:57PM
  Re: cheap Kinetic project, bad idea?Re: ben hooker ben hooker 06/01/12 11:31PM
  Re: cheap Kinetic project, bad idea?Re: Cosmo nPuch Stillstolen Cosmo nPuch Stillstolen 06/01/12 11:35PM
  Re: cheap Kinetic project, bad idea?Re: ben hooker ben hooker 06/01/12 11:37PM
  Re: cheap Kinetic project, bad idea?Re: Todd Hooker Todd Hooker 06/01/12 11:52PM
  Re: cheap Kinetic project, bad idea?Re: mit mortso mit mortso 06/02/12 12:25AM
  Re: cheap Kinetic project, bad idea?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 06/02/12 02:02AM
  Re: cheap Kinetic project, bad idea?Re: ben hooker ben hooker 06/02/12 09:55AM
  Re: cheap Kinetic project, bad idea?Re: Moped Jay Moped Jay 06/02/12 05:45AM
  Re: cheap Kinetic project, bad idea?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 06/02/12 07:15AM
  Re: cheap Kinetic project, bad idea?Re: Moped Jay Moped Jay 06/02/12 08:25AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/03/12 11:56AM
  Re: cheap Kinetic project, bad idea?Re: Leo Heyman Leo Heyman 06/03/12 12:53PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/05/12 12:44AM
  Re: cheap Kinetic project, bad idea?Re: -p0tty - -p0tty - 06/05/12 01:44AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/05/12 09:50AM
  Re: cheap Kinetic project, bad idea?Re: -p0tty - -p0tty - 06/05/12 10:13AM
  Re: cheap Kinetic project, bad idea?Re: Woot Senpai Woot Senpai 06/05/12 10:34AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/05/12 02:51PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/07/12 03:46PM
  Re: cheap Kinetic project, bad idea?Re: Bryan Butler Bryan Butler 06/09/12 01:26PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/07/12 09:26PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/08/12 09:17PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/09/12 11:14PM
  Re: cheap Kinetic project, bad idea?Re: Bryan Butler Bryan Butler 06/09/12 11:19PM
  Re: cheap Kinetic project, bad idea?Re: Tate The Great Tate The Great 06/10/12 12:14AM
  Re: cheap Kinetic project, bad idea?Re: Bryan Butler Bryan Butler 06/10/12 12:56AM
  Re: cheap Kinetic project, bad idea?Re: Adam Blickhahn Adam Blickhahn 06/10/12 01:13AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/10/12 07:44PM
  Re: cheap Kinetic project, bad idea?Re: Adam Blickhahn Adam Blickhahn 06/10/12 09:17PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 02:13AM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 02:22PM
  Re: cheap Kinetic project, bad idea?Re: Graham Motzing Graham Motzing 06/11/12 03:33PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/11/12 03:34PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 11:15PM
  Re: cheap Kinetic project, bad idea?Re: Patrick Keaton Patrick Keaton 06/11/12 11:31PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 11:44PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 11:52PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/14/12 09:26AM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/14/12 01:33PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/14/12 03:10PM
  Re: cheap Kinetic project, bad idea?Re: Patrick Keaton Patrick Keaton 06/14/12 03:24PM
  Re: cheap Kinetic project, bad idea?Re: discontinuuity _ discontinuuity _ 06/14/12 03:56PM
  Re: cheap Kinetic project, bad idea?Re: Patrick Keaton Patrick Keaton 06/14/12 04:01PM
  Re: cheap Kinetic project, bad idea?Re: discontinuuity _ discontinuuity _ 06/14/12 09:56PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/15/12 01:16AM
  Re: cheap Kinetic project, bad idea?Re: discontinuuity _ discontinuuity _ 06/18/12 11:45AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/18/12 10:13AM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/18/12 12:16PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/07/12 08:37PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/07/12 09:01PM
  Re: cheap Kinetic project, bad idea?Re: Jax Rhapsody Jax Rhapsody 07/07/12 09:16PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/09/12 03:48PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/11/12 02:16PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/16/12 09:39PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/24/12 04:58PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/07/12 01:01PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 07/24/12 07:03PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 07/25/12 01:19AM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/08/12 04:04PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/08/12 04:40PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/08/12 06:08PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/17/12 10:46AM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/08/12 10:06PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/17/12 02:54PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/17/12 03:37PM
  Re: cheap Kinetic project, bad idea?Re: Jax Rhapsody Jax Rhapsody 08/17/12 04:50PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/17/12 06:07PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/20/12 08:41AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/26/12 09:15PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 09/04/12 07:24PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 10/03/12 09:36AM
