on a side note. Plan on fixing this thing regularly for a little while. When things break, see if there is a vespa equivalent available. they are almost always better than the kinetic stuff. Careful though. alot of stuff looks close but isn't the same. Get a tube of thread lock and use liberally on most nuts. This thing will rattle to pieces, but once you get them "set up" they can compete with the best of bikes IMO. Treatland has pretty much anything you could want. If you have questions about compatibility just ask. Best of luck to you my good sir.
