Re: cheap Kinetic project, bad idea?
Aaron Miller /
You can buy 1'x1' squares of 1/8" stainless sheet steel at home depot in the roofing section for $10. I bought one and made a support for both sides and the little carb blocker since I removed the rear fender. you can see in the pictures. no welds necessary for this one. though I haven't tested it yet, but it seems much stronger than before. I did use an angle grinder a file and some sandpaper. and titanium drill bits to get through the stainless.
*you can make a nice template by placing a piece of cardboard against the sided of the subframe and applying pressure along the edge of the subframe as to dimple the cardboard. then cut it out and trace it on your steel sheet.
** I believe you will have to remove the engine and the rear wheel to properly mount it with nuts and bolts like I did.
*** I have a welder and opted out because the alloy of that subframe is so weak I was affraid it would just melt.
  cheap Kinetic project, bad idea?Topic by: preeesh . preeesh . 05/30/12 03:58PM
  Re: cheap Kinetic project, bad idea?Re: Don Sumpter (OFMC) Don Sumpter (OFMC) 05/30/12 04:08PM
  Re: cheap Kinetic project, bad idea?Re: Saabsonettguy . Saabsonettguy . 05/30/12 04:20PM
  Re: cheap Kinetic project, bad idea?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 05/30/12 06:22PM
  Re: cheap Kinetic project, bad idea?Re: Jimbo Grand Daddy Jimbo Grand Daddy 05/30/12 06:49PM
  Re: cheap Kinetic project, bad idea?Re: Woot Senpai Woot Senpai 05/31/12 11:37AM
  Re: cheap Kinetic project, bad idea?Re: Rick Ems Rick Ems 05/31/12 01:22AM
  Re: cheap Kinetic project, bad idea?Re: Stephen Keller Stephen Keller 05/31/12 01:31AM
  Re: cheap Kinetic project, bad idea?Re: mit mortso mit mortso 05/31/12 01:43AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 05/31/12 02:38PM
  Re: cheap Kinetic project, bad idea?Re: John Kiniston John Kiniston 06/01/12 08:32PM
  Re: cheap Kinetic project, bad idea?Re: felix the cat felix the cat 06/01/12 09:57PM
  Re: cheap Kinetic project, bad idea?Re: ben hooker ben hooker 06/01/12 11:31PM
  Re: cheap Kinetic project, bad idea?Re: Cosmo nPuch Stillstolen Cosmo nPuch Stillstolen 06/01/12 11:35PM
  Re: cheap Kinetic project, bad idea?Re: ben hooker ben hooker 06/01/12 11:37PM
  Re: cheap Kinetic project, bad idea?Re: Todd Hooker Todd Hooker 06/01/12 11:52PM
  Re: cheap Kinetic project, bad idea?Re: mit mortso mit mortso 06/02/12 12:25AM
  Re: cheap Kinetic project, bad idea?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 06/02/12 02:02AM
  Re: cheap Kinetic project, bad idea?Re: ben hooker ben hooker 06/02/12 09:55AM
  Re: cheap Kinetic project, bad idea?Re: Moped Jay Moped Jay 06/02/12 05:45AM
  Re: cheap Kinetic project, bad idea?Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 06/02/12 07:15AM
  Re: cheap Kinetic project, bad idea?Re: Moped Jay Moped Jay 06/02/12 08:25AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/03/12 11:56AM
  Re: cheap Kinetic project, bad idea?Re: Leo Heyman Leo Heyman 06/03/12 12:53PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/05/12 12:44AM
  Re: cheap Kinetic project, bad idea?Re: -p0tty - -p0tty - 06/05/12 01:44AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/05/12 09:50AM
  Re: cheap Kinetic project, bad idea?Re: -p0tty - -p0tty - 06/05/12 10:13AM
  Re: cheap Kinetic project, bad idea?Re: Woot Senpai Woot Senpai 06/05/12 10:34AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/05/12 02:51PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/07/12 03:46PM
  Re: cheap Kinetic project, bad idea?Re: Bryan Butler Bryan Butler 06/09/12 01:26PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/07/12 09:26PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/08/12 09:17PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/09/12 11:14PM
  Re: cheap Kinetic project, bad idea?Re: Bryan Butler Bryan Butler 06/09/12 11:19PM
  Re: cheap Kinetic project, bad idea?Re: Tate The Great Tate The Great 06/10/12 12:14AM
  Re: cheap Kinetic project, bad idea?Re: Bryan Butler Bryan Butler 06/10/12 12:56AM
  Re: cheap Kinetic project, bad idea?Re: Adam Blickhahn Adam Blickhahn 06/10/12 01:13AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/10/12 07:44PM
  Re: cheap Kinetic project, bad idea?Re: Adam Blickhahn Adam Blickhahn 06/10/12 09:17PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 02:13AM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 02:22PM
  Re: cheap Kinetic project, bad idea?Re: Graham Motzing Graham Motzing 06/11/12 03:33PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/11/12 03:34PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 11:15PM
  Re: cheap Kinetic project, bad idea?Re: Patrick Keaton Patrick Keaton 06/11/12 11:31PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 11:44PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/11/12 11:52PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/14/12 09:26AM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/14/12 01:33PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/14/12 03:10PM
  Re: cheap Kinetic project, bad idea?Re: Patrick Keaton Patrick Keaton 06/14/12 03:24PM
  Re: cheap Kinetic project, bad idea?Re: discontinuuity _ discontinuuity _ 06/14/12 03:56PM
  Re: cheap Kinetic project, bad idea?Re: Patrick Keaton Patrick Keaton 06/14/12 04:01PM
  Re: cheap Kinetic project, bad idea?Re: discontinuuity _ discontinuuity _ 06/14/12 09:56PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/15/12 01:16AM
  Re: cheap Kinetic project, bad idea?Re: discontinuuity _ discontinuuity _ 06/18/12 11:45AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 06/18/12 10:13AM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 06/18/12 12:16PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/07/12 08:37PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/07/12 09:01PM
  Re: cheap Kinetic project, bad idea?Re: Jax Rhapsody Jax Rhapsody 07/07/12 09:16PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/09/12 03:48PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/11/12 02:16PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/16/12 09:39PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 07/24/12 04:58PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/07/12 01:01PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 07/24/12 07:03PM
  Re: cheap Kinetic project, bad idea?Re: Aaron Miller Aaron Miller 07/25/12 01:19AM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/08/12 04:04PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/08/12 04:40PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/08/12 06:08PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/17/12 10:46AM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/08/12 10:06PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/17/12 02:54PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/17/12 03:37PM
  Re: cheap Kinetic project, bad idea?Re: Jax Rhapsody Jax Rhapsody 08/17/12 04:50PM
  Re: cheap Kinetic project, bad idea?Re: Maciek Dub Maciek Dub 08/17/12 06:07PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/20/12 08:41AM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 08/26/12 09:15PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 09/04/12 07:24PM
  Re: cheap Kinetic project, bad idea?Re: preeesh . preeesh . 10/03/12 09:36AM
