here's what I did with mine. Finishing up on tuesday.
-Kinetic TFR reinforced subframe, frame, and forks
-Vespa Malossi Reed intake speed case
-Vespa Malossi Big D.E.P.S cylinder/piston/hi-comp head
-19mm phbg carb + Malossi hi-flow filter
-Vespa variated wheel set
-big Simonini Pipe
-Polini speed control variator, stock rear w/blue polini spring
-Olympia race gear set
-custom rattle can paint job
Let me know if you have any questions, and I will repost when I am finished with this. I just R&R'd everything on this bike, and it is all fresh in my memory. This is also my third TFR, I know these bikes pretty well. email me if you need some answers man. and good luck to you. can't wait to see it going!
