A-3 Intakes
Mariano Ulibarri /
I've got an old A3 that I am trying to get going & wondering what alternatives to the Encarwi there are. Right now I have a complete engine sans-intake.
Re: A-3 Intakes
The earlier A3 models had the Encarwi, and the later A3 models had the Dellorto SHA.
Re: A-3 Intakes
Re: A-3 Intakes
I have the stock dellorto intake but am experimenting with copper plumbing pieces to get the carb off to the side for under $50 Sucks changing jets with it in the original spot
Re: A-3 Intakes
i have plenty of intakes if you want one, and the encarwi is better than the 14:12 delorto, stock, for sure, for whatever reason i always had airleaks with the dellorto.
if you throw a a3 reed kit on there, go straitshot with dell 15.
Re: A-3 Intakes
Mariano Ulibarri /
Thanks for all the input!
I have an old A35 Airsal that I think I'll put on it. Treats has the 10mm pistons for it & that would simplify things quite a bit.
Re: A-3 Intakes
Do what I did, take an old puch crank, press the brass bushing out, press the one out of the Tomos, press puch one in, run any a35 or puch kit on it, a3's have better clutches anyway.
