Help with my magnum
Paul Ramirez /
My Magnum is flooded and it won't start? Does anyone know how I could fix it?
Re: Help with my magnum
sir thaddeusforemen /
You might wna post this in the Repair section.
spark, go through the wiring
move it to hyer ground
It takes 3 things for an engine to run.
Gas
Spark
Compression
If your engine doesn't run... 1 of those 3 things is gone.. or not good enough. (if your engine has all 3 of those things.. IT WILL RUN.. it does not have a choice!)
The 3 most common reasons why mopeds don't run are....
Dirty carburetor (inside)
Fouled spark plug.
Dirty, worn, or mis-adjusted ignition points.
Courtesy of the WiKi Section
Patrick Keaton /
Remove the spark plug and act like you do when you try to start it, but with the spark plug removed. Do this for along time.Hold the spark plug in one hand, and pound the spark plug into your other hand to clean out the inside of the spark plug. Is the float bowl overfilling ? Are all the seals and gaskets good ? You may need an o ring between the carb and the intake manifold. Is the intake manifold tight enough ? (edited)
Paul Ramirez /
Thanks everyone I got it started!
