e50 tunning problems
I have a e50 with modified stock cylinder, shaved head, 13mm intake, stock bing 12mm carb. Im having some tunning issues, the carb is to lean on the bottom end but to rich on the top end. Im running 93 octane fuel and a champion L86C plug
Re: e50 tunning problems
You could try adjusting your slide needle, but that also sounds like it could be that you're jetted too high, but have a small air leak as well.
It has a 62 jet and is leaned down as much as it can go, it i richen it one click then the top end is way rich
bigger atomizer,allows more gas in with throttle down and a smaller jet for leaner top end.
try bigger atomizor same jet then play with the needle. what slide? theres the #24 slide mod, for after if your rich at idle.
Overpriced Parts /
#64-66 jet if #222 atomizer in carb
as alex boyd, he could probably figure it out for ya
*ask
alex doesnt know what to do my bike is sitting at his house now being worked on
