104 Peugeot gas in tank
Just acquired a BB 104 PEUGEOT - has rust in gas tank how do I remove it - any suggestions?
Re: 104 Peugeot gas in tank
Check the wiki. There are many ways to do it.
to get rust and crap out of a tank. we first drain all the shit out. then take the cock out and hook a hole up to the gas filler thing and keep runing water through. then we stick an air hose to the petcock end and bubble the water inside. do this a ton of times. then fill with gas let sit, dump gas out and repeat 5 times. them put all the shit together and rip
I like tuo use the pressure washers at the car wash. Acid works great and so does reverse electrolosis. Check the wiki for a lot of ways to see what you want or can do.
i just did a por15 it came out nice.
4 years and my por-15 puch is still clean as a whisle.
