Tomos: How big can you go on rear tire?
.♠.MSG .♠. /
Tomos: How big can you go on rear tire with factory A arm.
2.75?
Re: Tomos: How big can you go on rear tire?
2.5
Andrew Squiggman /
^^ yes 2.5 that leaves about 1/4 inch clearance to the pivot cross bar.
.♠.MSG .♠. /
Thank you
Seth Cameron /
I have 2.75" but I had to let all the air out of the tire and compress it (two person job usually) to get it into the drop outs. It also required using an ofset link in the chain.
Andrew Squiggman /
I think it depends on the tire too. They dont seem standard by size, even brand. I took Sava MC2's off that were 2.25", and put on sava B8's, at 2.5". the 2.5 measured the same across the fattest part of the tire inflated as the 2.25 mc2's. the 8's though seemed to be a bit taller though.
.♠.MSG .♠. /
i want to put a 2.75 without buying the robot A arm and just wanted to make sure before I purchased
