gotta lace a vespa hub. anyone know what fits? pref 17"
I just sacrificed an aluminum moby front wheel to relace my hobbit rear 17"
Is it 36 or 32?
I couldn't find anything on eBay. Maybe an older used CR80 rim would work? They're 17" but I'm not sure about the hole count.
oh shit they might be 32, im a asshole
You can re-drill rims to have different number of holes
> holes
Really? they won't be evenly spaced though. guess it probably doesnt matter that much but at that point couldn't you just omit the extra holes in the hub more easily?
Anyhow, you coan pick up some rad heavy duty dirtbike rims, (and in sweet anodized colors) pretty easily. try searching for the suzuki RM80, I know at least those run 36 hole 17's
Actually you can space the holes perfectly. You need to measure the circumference and do simple math
yeah but when you factor in the diameter of the hole you'll more than likely end up having to basically elongate an existing one. Its not like you're going from 6 to 5.
