any tips on what type of bar or piece of sheet metal to use to start cafe conversion.
Experience speak up!
32 gauge moped spec pot metal
what are you trying to make?
Garbage metal or doom metal
2" DOM tooooooob
Throw in some 3" as well
DOOOOOOOM
I prefer speed metal cuz it makes your ped go faster. what, you didn't know that?
dude! use cromo (no homo)
just go to your nearest fallen down building and look for the steel you need... if the scrappers havent gotten it first
Crossbar? Use a fence post. they're are cheap. Be sure to grind off the galvanized shit before you weld.
Measure the radius on your tank channel. Then buy a pipe that is the same putter diameter as that in the correct length. Don't use a fucking fence post. There will most likely be compound bevels on both ends of your new pipe thy will take a bit of brain power to figure out for a good fitment. So don't just go starting in on hacking it up. Stand back and think about it for a second. Use a mild steel pipe.
I used a fence post. It worked fine for me.
galvinized stuff melts like butter, and emits good smells, drink your milk folks
So fence posts are all the rage, huh? Ok.......
Actually, use multiple rolls of tinfoil packed really tight. Then used duct tape to hold the pieces together. At the ends, use zip ties to hold it to your frame.
any advice on reattaching the tank to the cross bar? weld, bolt, or super glueeeeeee.
magic. Black or white should work.
meh worked fine for me.
EXCEPT NOW YOURE DYING
Jb weld and a couple paper towel rollzzzzzz.
Buying small quantities of metal can be a pain in the ass. Metal supply shops are not set up for us, and big box hardware shores have shit for selection and outrageous prices. I wouldn't rule out ebay, you can get some small pieces of good tubing for a reasonable price sometimes. DOM is best. I would look for something thicker than 14g.
Zinc oxide poisoning from welding galvanized metal is inconvenient. Like a shitty hangover. I don't know if I buy the whole story about milk protecting you from it...
There is little/no information about long term negative effects of zinc oxide. It's an ingredient in children's cereal and sunscreen, yes?
I'd make a mock-up out of a cardboard tube to get practice figuring out the bevels n' shit. When you get that right, copy it onto steel. You can roll a cardboard tube of any diameter you want. So much easier to wreck that with a mistake and start another one in cardboard than to wreck a steel on and have to start over.
Milk does nothing except give you something to throw up on your shoes. If you are welding galv, make sure to wear the proper repirator.
I use mild steel. I buy a 4ft section and is an angle grinder to shape it.
We did it, no one got sick. Just saying. We was tryin to get high off the zinc oxide and but that shit was wack, didn't feel a thing.
I was sure to get all the galvanize coating well off the part near where we welded.
I made an s rail from a trampoline frame. And all the gasses go stuck in my welding mask. Twas great yo!
This.
Don't even bother with galvanized, a lot of that fence post stuff is pretty thin walled anyway. Check your local steel supplier for scraps.
