Change out the condenser for a external one, replace the bonding strap with a longer one from coil to carb stud instead of the swivel mount.
Index points points 0,35 - 0,40mm (.013-.016 inch) then set to 1,5mm BTDC instead of 2,0 BTDC.
Clean the exhause and the exhause port.
