Hey, Casey...
When you put that performance exhaust on the PA-50, what, if anything, did you do to adjust timing, carb jet, etc.? Had you done the variator ramp mod? Or was it just bolt on and go? I'd like to get a little more ooomph out of mine, but would rather not mess with a new carb or anything if I don't have to. Thanks.
Re: Hey, Casey...
hey, i just adjusted the mixture screw to be a little richer... i did do the ramp variator mod, and that helped out a little... i would definitely reccomend doing both. not very much money (or time) and your pa50 will have more power than you know what to do with. i still havent messed with the timing (it could probably stand to have it set, but i havent felt like messing with it)...
but make sure you do plug chops (after getting the exhaust)and make sure you arent running too lean... good luck...
casey
Re: Hey, Casey...
Yeah Bill. Casey's moped is fast as hell! Do it up!
