Chain tension
What is the correct amount of tension on the drive chain for a Puch Maxi 1 speed? I am sure there is a more scientific appraoch than the "o'bout" method.
Re: Chain tension
Okay,direct from the 2-speed manual.One-speed should be the same.With laden weight(approx.165lbs.) there should be 3/4" deflection from straight at the bottom when you lightly pull down.This is in order for the chain not to overtighten if you hit a bump and compress the swing arm to a straighter position in relation to the engine.
Re: Chain tension
I am always checking the chain tension and lubrication. It is one of the simpler things you can do for optimum performance and noise reduction.
