Suzuki Fa 50 choke
Someone please tell me how this choke works so I can fix mine. I do not even understand the design. Its a cable choke and its got a little gold body, and where it goes in the carb, its a very tight fit. So tight it seems that when you snug up the top nut for the choke on the carb the little gold body has no room to pivot? and at the bottom of the chamber where the gold body sits there is a very skinny tube that goes directly into the bowl?? Never seen a choke like this. Some help would be appreciated
Re: Suzuki Fa 50 choke
that choke just slides up and down a little bit, do you have the right cable hook up and everything. there should also be a spring on top of it to push it back down. NC 50 and Indians mopeds have the same set up, with the mikuni carbs.
Yes its all there and all original. It moves up and down but then what? any ideas on troubleshooting??
so nobody knows anything? so much for good help
Bump
bump
Suzuki Fa 50 choke
Steamboat Aka J. R. Stevens /
