RE: should I fix it myself ?
Fred /
Make sure you look for the locater pin in the ring grooves of the piston..... that is where the split in the ring goes...... and if you don't have that lined up when you assemble it you will damage the cylinder and the ring..... also make sure the rings are right side up.... the side of the rings that faces the spark plug normally have small letters stamped on them
  should I fix it myself ?Topic by: moby moby 09/11/00 05:04PM
  RE: should I fix it myself ?Re: Ivo Ivo 09/11/00 06:37PM
  RE: should I fix it myself ?Re: Daniel Daniel 09/11/00 09:00PM
  RE: should I fix it myself ?Re: Fred Fred 09/13/00 05:41AM
