hi
has anyone on this forum had any luck with fitting the cdi unit and primary coil off a tomos a35 onto a puch maxi e50 engine (using the puch maxi 6 volt lighting coil and puch maxi flywheel) as i have the white primary coil and the two wire cdi unit but not the lighting coil, so hoping that a mis match of parts will still make the bike run (need to know what side to put the primary coil and what spark plug to use and what gap to run on the spark plug and timing point), thank you for any information on this subject .
