I think I have a 1978 Puch Maxi MKII, I need to know more about it. What type of motor does it have, if it uses a mixture of gas and oil/what type. Is it considered a Moped.I'm planning to restore it
info on 1978 Steyr Daimler AG Puch
Re: info on 1978 Steyr Daimler AG Puch
Yes it's a moped. Looks like it has the za50 2-speed engine. Use premixed gas at 50:1
mix regular gas with premix 2 stroke oil, mix at 50:1. it is a moped, yes (moped = MOtor + PEDals)
this is pretty much the most common moped around, so just search around on the forums/wiki for puch maxi and you'll find all of the info you want.
Puch moped 1.5 hp za50 engine
50 to 1 2 stroke oil
That's an e50 dudes. Short intake and no oil hump on the case.
Haha, looks like someone took the back half of a cigar air box and connected it in reverse to some rubber hose.
Ya if it is a mk ll someone took off the za50 and put a e50 engine on it
Or it's a maxi sport
definitely E50. no rear coil mounts either.
