clutch not disengaging
Just did a rebuild on my Maxi ZA50, i think i may have tightened something too much though because it doesnt move freely, ie moving the rear tire cranks the engine. The starter cable isnt even attached and it does this. Anyone have any advice before i tear it open again?
Re: clutch not disengaging
Shims are probably not right. Did you replace any parts or just take it apart and reassemble?
Just took it apart and reassembled. did a full teardown though, to the output shaft, which i replaced the bearing on.
Yep, take it apart, check your assembly order, check your torques, make sure your shims are seated correctly.
