HELP:Puch snowflake rear reassembly
☠ Leg! ☠ /
So i know this is a terrible question but i took my rear brake off with all of the bolts on the axle. Trying to reassemble but the brake plate does not seat well. am i missing a spacer? if i just put the plate on the lil arm that sticks out sits to close to the gear. Any links? Pics? See my pic for an example.
Re: HELP:Puch snowflake rear reassembly
I think you need the inside spacer between hub and bearings. You can use 12mm (or 11mm, if yours is stock) washers, probably 5-6 spacers will do the trick.
☠ Leg! ☠ /
Ok yeah i have a spacer here in the parts but when i put it beween the hub and bearing the plate sticks out a lil weird. Idk if this is ok. Doesn't seat nice on the hub. But now i know what to work with. Thanks for the help
