Re: Peugeot 103 starting help!!
Zippy /
Maybe a bad reed valve.
Go to this link to see how a Reed valve works. It basically should create a vacuum on the downstroke to cause the gas to be sucked into the chanber. If it is defective it will not create the vacuum to keep sucking in the gas.
<http://www.howstuffworks.com/two-stroke2.htm
It could be the reed valve or a own head gasket or defective engine gasket seals. Any of these would cause an air leak that would prevent a vaccum from being created.
  Peugeot 103 starting help!!Topic by: Russ Russ 03/10/02 04:29PM
  Re: Peugeot 103 starting help!!Re: duck duck 03/10/02 11:40PM
  Re: Peugeot 103 starting help!!Re: dan dan 03/10/02 11:41PM
  Re: Peugeot 103 starting help!!Re: KelvinKDX KelvinKDX 03/11/02 12:02AM
  Re: Peugeot 103 starting help!!Re: duck duck 03/11/02 01:04AM
  Re: Peugeot 103 starting help!!Re: russ russ 03/14/02 07:30PM
  Re: Peugeot 103 starting help!!Re: Zippy Zippy 03/14/02 08:19PM
  Re: Peugeot 103 starting help!!Re: Zippy Zippy 03/14/02 08:25PM
