Re: Peugeot 103 starting help!!
russ /
I have cleaned the carb three time, I even took the filter out to see if it was slowing down the flow, but there was no change. The choke didn't matter either, it still only runs for about 2 secounds and the only way I can get it to start again is to remove the gas line from the carb for a secound.
Its seems to not be sucking the gas. I know the flow from the tank is fine and I know the gas is getting into the carb, could it be a problem further up the line? a compression problem?
I'M SO CLOSE!!!
  Peugeot 103 starting help!!Topic by: Russ Russ 03/10/02 04:29PM
  Re: Peugeot 103 starting help!!Re: duck duck 03/10/02 11:40PM
  Re: Peugeot 103 starting help!!Re: dan dan 03/10/02 11:41PM
  Re: Peugeot 103 starting help!!Re: KelvinKDX KelvinKDX 03/11/02 12:02AM
  Re: Peugeot 103 starting help!!Re: duck duck 03/11/02 01:04AM
  Re: Peugeot 103 starting help!!Re: russ russ 03/14/02 07:30PM
  Re: Peugeot 103 starting help!!Re: Zippy Zippy 03/14/02 08:19PM
  Re: Peugeot 103 starting help!!Re: Zippy Zippy 03/14/02 08:25PM
