what is the tire size for a tomos LX
i need to Know what size the tire tube size would be for a tomos LX.
Re: what is the tire size for a tomos LX
The tire and tube are 16 x 2.25
Ike
Evan Schmidt /
can you get away with a 2.50 or a 2.75?
A 2.50 will just barely fit, unless your chain is so short that the axle is all the way forward (which isn't really a good idea, as the slot to drop the axle out is all the way forward). You also will probably have to bend the front part of the rear fender a little wider. You can do that with pliers. I don't think a 2.75 would work on an LX. I have an LX and I had a 2.50 on it last year.
