Re: for zippy/72 Ciao flywheel
bruce /
Thanks so much for your time and patiance. I have seated the flywheel all the way down with the woodruff key in position , engine is flat on the bench. Then the plastic flywheel cover is screwed on, still flat on bench. When I turn the engine on it's side the way it goes on the bike,the flywheel is not snug on the shaft. It can't fall ,the plastic stops that but it is not held tight to engine IT RATTLES ,but is still in the key. I just thought it should (clamp) onto the taper. When the hell do you get a chance to do any riding with guys like me around ? thanks bruce
  for zippy/72 Ciao flywheelTopic by: bruce bruce 03/04/02 10:49PM
  Re: for zippy/72 Ciao flywheelRe: Jim C. Jim C. 03/04/02 11:44PM
  Re: for zippy/72 Ciao flywheelRe: bruce bruce 03/05/02 12:31PM
  Re: for zippy/72 Ciao flywheelRe: Zippy Zippy 03/05/02 01:52PM
  Re: for zippy/72 Ciao flywheelRe: bruce bruce 03/06/02 08:03PM
  Re: for zippy/72 Ciao flywheelRe: Zippy Zippy 03/06/02 10:12PM
  Re: for zippy/72 Ciao flywheelRe: bruce bruce 03/07/02 07:22PM
  Re: for zippy/72 Ciao flywheelRe: Zippy Zippy 03/05/02 01:27AM
