RE: No torque, no acceleration.
Dan /
If nothing of the above helps, try checking the compression in the cylinder. (1) You might need to replace the piston rings with new ones if you don't know for sure the total mileage of the bike. (2) However the replacement will not be necessary if the rings just got charred in the grooves due to excess of oil or wrong oil used. In this case just soak the piston in gas or in a special solvent to remove char. Avoid using car oil when preparing the fuel. It produces a lot of buildup all over the combustion chamber and the exhaust manifold. Stick to 2-stroke oils.
CORRECT OCTANE NUMBER: if the compression ratio (see manual) is below 8 you can use 87 gas. If it's 9 thru 11 use 92 gas.
  No torque, no acceleration.Topic by: Tom Tom 08/31/00 08:34PM
  RE: No torque, no acceleration.Re: mopedman mopedman 08/31/00 08:39PM
  RE: No torque, no acceleration.Re: Tom Tom 09/02/00 06:46PM
  RE: No torque, no acceleration.Re: Fred Fred 09/01/00 01:00AM
  RE: No torque, no acceleration.Re: Dan Dan 09/01/00 07:52AM
  RE: No torque, no acceleration.Re: Daniel Daniel 09/04/00 05:34AM
  RE: No torque, no acceleration.Re: Fred Fred 09/04/00 02:13PM
  RE: No torque, no acceleration.Re: Skeeks Mcgee Skeeks Mcgee 09/01/00 06:35PM
  RE: No torque, no acceleration.Re: Fred Fred 09/02/00 12:05AM
  RE: No torque, no acceleration.Re: Reeperette Reeperette 09/02/00 10:33PM
  RE: No torque, no acceleration.Re: bill bill 09/12/00 03:22AM
