Doppler Clutch Pulley. I need HELP!
Charlie Carder /
Hi everyone,
this is my first post to this forum. I'm putting my bike back together after having a respray and thought it would be a good time to make her go faster. The problem is I can't work out how the clutch pulley fits. The pedal axle that came with it seems far too long and it didn't come with any circlips or other fittings. If anyone could help I would be over the moon. :)
Re: Doppler Clutch Pulley. I need HELP!
The shaft that comes with the clutch pulleys as far as I know are not meant to be used with pedals. The notches for the cotter pins are probably on the same side as well, making it useless for pedals. I didn't think they were that much longer though; do you per chance have a peugeot pulley on a moby or vise-versa?
Charlie Carder /
I suppose I could have bought a peugeot pulley by accident. I bought it from France and my french isn't too good. This pedal axle is just about twice as long as the stock one.
Weird. Can you measure it, tell us the length?
The doppler clutch pulley is the same for motobecane and peugeot. The pedal shaft will be longer to accommodate the thicker clutch pulley. Got a picture?
This one?
https://www.treatland.tv/doppler-pedal-shaft-p/doppler-mbk-pedal-shaft.html
Charlie Carder /
> Got a picture?
> This one?
Yeah, thats the one.
Charlie Carder /
BUMP!
Bump for what?
Sounds like you just need to get some circlips.
Charlie Carder /
Mars™   Wrote:
> Bump for what?
I'm not sure how the pulley attaches to the pedal shaft. :)
Tracy Meade /
You slide it on. It spins on the shaft, held in place between a circlip and your frame.
