Need To Unrust Cotter Pin From Pedal Shaft & Don't Know How
Like the subject says, cotter pins rusted to he pedal shaft. Any advice on how to undo that?
Re: Need To Unrust Cotter Pin From Pedal Shaft & Don't Know How
Pb blaster
Jimbo Grand Daddy /
Buy a new one at your local bike shop. PB Blaster and a hammer. Then replace.
send your moped to me in canada. i will free it up and send you back your cotter pin! and i will make a youtube video of it!
fallout Survivor /
Try the PB Blaster, or WD-40,
alternately Naval Jelly, or strong acid. (carefully it can blacken chrome.).(edited)
try a little heat and pb blaster. don`t beat on it too much you`ll bend the pedal shaft.(edited)
A Boy Named Britchez ... /
Pb then unscrew then nut to sit flush at the top of the threads so u have more area to wack at rather than just the end of the pin. Try a rubber mallet first before a metal hammer and u might be able to salvage the pin.
Charlie Carder /
Try this. I know its expensive but I use this every day at work and it will shift even the most stubborn cotters if you team it with some dismantling fluid.
http://bikesmithdesign.com/CotterPress/index.html
:D
fallout Survivor /
That press is a nice tool for a shop, kind of pricy for a one off job.
Maybe if there is room, try a very large c-clamp instead?
press > hammer > C-Clamp
presses are awesome if you have access to one, otherwise...
you need the shock from the hammer strike to break the corrosion. you may want to buy/borrow a sledge hammer. leaving the nut on the end will work, but a metal punch in addition works even better to help line up the hammer strike force parallel to the direction the pin needs to move. hold the punch with a pair of pliers as they tend to go flying when whacked with a sledge.
you should probably use a vise or c-clamp to prevent the pedal shaft from moving when you wale on it with the sledge.
dont use a screwdriver instead of a punch, the plastic/wooden handle will absorb some of the shock. you need all the shock you can muster.
i have a 3lb, 1' wooden handle, sledge hammer that i use often and a set of 3 metal punches(very cheap and crappy), all acquired from lowe's. You could also "borrow" (buy, use, return) a sledge from walmart.(edited)
Little heat and some atf
Sledge will bend the threaded end. Just use a hammer and Tappa Tappa Tappa. Sometimes I use a 1/4 inch socket extender to place on the threaded end after I put a nut on it to have a decent area to strike.
$55 for cotter pin tool? My bike cost $180!
John Warren IhazJawas /
i used liquid wrench then a hammer and pick and bought a new cotter
So that's what the Buy & Return is called: "borrowing". I'll go borrow me a torque wrench; they're expensive and I haven't committed 100% to one.
