This is $60 + $20 shipping however if any one has the equipment to Fabricate that Adapter you should do it make it easier on us other owners to Bolt on a Dellorto with out all the mods to make it work
Attention Jawa Owners
Re: Attention Jawa Owners
puch intake is pretty much direct bolt on fit... enlarge the holes, make a gasket maybe? So there is already an SHA intake that works
https://www.treatland.tv/puch-dellorto-SHA-15mm-intake-p/puch-dellorto-sha-15mm-intake.htm
that adapter is kind of dumb because the stock intake is waay small(edited)
Nick is very correct,
this set up was used by factory in last series when Jikov stopped to supply carbs, utilizing original tiny steel intake- worked quite nicely.
John, search Jawa repair/performance posts wayyy back- it has been described, pics posted.
You will be able to use existing throttle cable with a little adjustment.
I do not have any intakes left, get Puch intake from Benji- the cheapest one- for SHA, make sure the carb you get has correct size sealing ring and adjust the holes with rounded file and narrow the stem filing it down to fit into recess on the cylinder, make new gasket from gasket sheet.
Not to mention all the time needed to drill sand cut gaskets plus the cost of said gasket material i say this setup is ideal for the guy like me who doesnt have all the tools and equipment to make something fit that wasnt made to fit i have a wrench and ratchet thats the extent of my tools
Started to tare down my parts Jawa and put the stock exhaust on my ridable bike after drilling out the baffle of course(thanks for the tip on that), on my good bike the stem in the exhaust was pulled out so i didn't have a baffle on sounds good now had to readjust my carb because it was stalling with the new(old) pipe on it
and when i pulled off the air filter it crumbled to dust good thing i wasnt planning to use it
why spend money on a larger carb just to run it on a restricted intake.
why is it restricted im not widening the hole in the engine i havent seen anyone do that in all the mods i looked at so its still fed at the same rate whether its a mod in take or not i could be wrong but thats how i see it
do you wanna go faster than 27mph?
guess not
my bike goes 35 now with the jikov carb and stock i just drilled out the baffle yesterday what are you talking about 27
ok 35 is rounded its about 32 flat out
if you arent trying to put a phbg/mikuni/oko on things, dont worry about the size of your carb.
