tomos robot swing arm biggest tire
will a 3.25x16" tire fit in an a35 robot swing arm?
Re: tomos robot swing arm biggest tire
John Joedicke /
Yes but you need to space it, and use the dished sprocket on the front.(edited)
GET REALIZED! BE HERE NOW! /
bigger problem the fact that the robot arms are made like shit
not going through all that. think i will just stick with a 2.75. thanks for the pic.
Don't know what a "robot arm is" . . . The Streetmate comes with a 3.25 x 16 rear tire. The rectangular cross-section swingarms they are using now have a lot of room side-to-side, even on the LX, ST, and Sprints. They might fit an old A35 frame, but I don't know for sure.
John Joedicke /
Swing arm bolt length is all the same on all Tomos models. Streetmate/Revival swing arm bolts on but needs to be squeezed in a bit at the axle if you are installing on a LX type frame setup. Spacer at rear and dished sprocket at the motor is only to clear the chain from the tire. Use a Streetmate axle.(edited)
where can the spacer be had or does one have to make it?
John Joedicke /
Go to TSC and purchase the size of weld on sprocket hub you require. Machine it to the thickness you require. Mount it with longer hardened SAE bolts.
thanks
