Re: What kind of forks are they?
Tim Annett /
There are no drain holes on the bottom. There is a nut on the bottom of each one that holds the internals in place. Don't undo that nut unless you plan on rebuilding them and have all the necessary seals and fiber washers on hand. Likewise if you pull the too large nuts holding the fork legs onto the triple tree hold the forks upright while doing so or all the oil will spill out.
As to what else they will fit: any Puch moped and I'm probably not many other mopeds without modification. However size wise they are much longer than maxi/newport forks so really to answer your question they will fit on a Puch magnum.
  What kind of forks are they?Topic by: Terry Gerker Terry Gerker 11/24/11 12:06PM
  Re: What kind of forks are they?Re: Weak-Ends Tj Weak-Ends Tj 11/24/11 12:16PM
  Re: What kind of forks are they?Re: Goose . Goose . 11/24/11 12:17PM
  Re: What kind of forks are they?Re: Terry Gerker Terry Gerker 11/24/11 12:23PM
  Re: What kind of forks are they?Re: Joe Schuitema Joe Schuitema 11/24/11 12:24PM
  Re: What kind of forks are they?Re: Saabsonettguy . Saabsonettguy . 11/24/11 12:56PM
  Re: What kind of forks are they?Re: Elyse Hot&Shwetty Elyse Hot&Shwetty 11/24/11 01:17PM
  Re: What kind of forks are they?Re: Zazu Pits Zazu Pits 11/24/11 01:22PM
  Re: What kind of forks are they?Re: j throne j throne 11/24/11 01:28PM
  Re: What kind of forks are they?Re: Mike Boyd Mike Boyd 11/24/11 01:42PM
  Re: What kind of forks are they?Re: Reynold Cortigine Reynold Cortigine 11/24/11 03:49PM
  Re: What kind of forks are they?Re: Terry Gerker Terry Gerker 11/24/11 07:25PM
  Re: What kind of forks are they?Re: Blake MD No PM Plz Blake MD No PM Plz 11/24/11 08:56PM
  Re: What kind of forks are they?Re: Terry Gerker Terry Gerker 11/24/11 09:35PM
  Re: What kind of forks are they?Re: Tim Annett Tim Annett 11/24/11 09:12PM
  Re: What kind of forks are they?Re: Terry Gerker Terry Gerker 11/25/11 07:43AM
  Re: What kind of forks are they?Re: Tim Annett Tim Annett 11/25/11 09:08AM
  Re: What kind of forks are they?Re: william hautenredi william hautenredi 11/25/11 09:13AM
  Re: What kind of forks are they?Re: br∞ks readman br∞ks readman 11/25/11 09:41AM
  Re: What kind of forks are they?Re: Jerry bojo Jerry bojo 11/25/11 10:54PM
  Re: What kind of forks are they?Re: Goose . Goose . 11/25/11 11:00PM
  Re: What kind of forks are they?Re: Terry Gerker Terry Gerker 11/26/11 08:17AM
  Re: What kind of forks are they?Re: Terry Gerker Terry Gerker 11/27/11 02:54PM
