What kind of forks are they?
Found them in a box of parts, but don't know what they fit. Anybody know?
Re: What kind of forks are they?
They look like some kind of Puch forks..
vespa grande?
nope the clamp on the bottom of the tree exclude vespa (edited)
Could they be for Derbi?
Joe Schuitema /
Puch magnum forks. Not sure if spring or hydraulic.
They are the ideal forks for your next build.
they look like the forks off my sisters batavus starflite minus
Magnum
ideal forks.
yup. silver magnum mkII forks. Hydraulic I think.
Reynold Cortigine /
free spirit?
Wow! That is alot of choices. Anyone no for sure?
They look like my magnum mkii forks. Are there drain holes on the bottom? puch or not they look to be good quality
Puch Magnum MK II Hydraulic forks 100%
where would the drain holes be?
Many say Magnum.
There are no drain holes on the bottom. There is a nut on the bottom of each one that holds the internals in place. Don't undo that nut unless you plan on rebuilding them and have all the necessary seals and fiber washers on hand. Likewise if you pull the too large nuts holding the fork legs onto the triple tree hold the forks upright while doing so or all the oil will spill out.
As to what else they will fit: any Puch moped and I'm probably not many other mopeds without modification. However size wise they are much longer than maxi/newport forks so really to answer your question they will fit on a Puch magnum.
Magnum hydros for sure.
they're hydraulic
Definitely 100% Playtex Maxipads!
^ this
Looks like Magnum has it. Thanks for you help!
I have no Magnum to put them on, so I guess they go on buy and sell soon. Thanks for all you help.
