Maybe I Have Chinese Knockoff Tomos
xeta prime /
Okay, just kidding but I need to rant a little.
This morning, I don't know how I did this, but I realized I'd put the pedal shaft spring sleeve on the wrong side. I'd even looked at the diagram beforehand. Fine. The freakin' cotter pins of course wouldn't come out. Fine. Heat gun, rubber mallet lightly, nope. Vice grip on edge of pedal and top of pin, yes. Fine. The plastic side panel was put on in a way that the shaft sleeve wouldn't go on, meaning the shaft wasn't centered in the plastic chrome opening. It was butt up against the pedal shaft. I also noticed that whoever assembled the bike stripped the bolt holding the cover on! Of course it's just the tip, but it's got it's own threads now, slightly off from the rest. Fitting the plastic cover on so the shaft was centered and the sleeve would go on wasn't working. Remember I had trouble with the plastic Revival tank fitting over the battery. I swear on this green polluted Earth I know how the battery was supposed to fit. On it's side with the rubber strap. Didn't work. So I had to dremel the hole like a 16th of an inch larger so the sleeve would fit. Fine.
Anyway, it's all back together.
Uploaded with ImageShack.us
And I'm broke so I can't pay to register it until Dec 1. Fine.
Thanx for letting me rant,
Xeta
