Re: Hobbit Convoluted Issues, puzzeling
your getting closer keep at it. i have ran quite a few clones and ginsu e-bay carbs that worked great.
Hmmm...... Tried to ride it, it doesn't have enough power to pull with my weight on it. On the kick stand, she seems to run fine.
Update, seems its no low end, once you get the bike moving to about 10mph she'll start to rip.
Master D. Baiter /
turn them screws to fine tune it. start with them in, then backed out 2 turns then give it what it wants.
jack, do you have a clutch puller yet? I mean can you get at your stock clutch springs.
I still think your Idle jet is too big, your points are set too close, air screw is too far out. On the stand what does it do at about1/8ththrottle twist?
On the stand at 1/8 there is a "hint" of a bog, then it it takes off. No points on this guy, its CDI. I can down the idle jet some more and see what it does.
