Where do you get those little red plastic plugs?
I see some pictures of drum brakes with the clean-out holes plugged with little red plastic plugs. Where do you get those? I asked at the local hardware store and they had no idea what I was talking about.
Re: Where do you get those little red plastic plugs?
Try buy/sell forum? Maybe a surplus store, you prob will not be able to buy them new, but may be able to find something similar. Maybe a motorcycle wrecking yard, treats? Mopedjunkyard.com?
discontinuuity _ /
I've seen similar plugs used to plug up other stuff, so I don't think they're just for brakes.
Jason Jason Bobason /
John Warren IhazJawas /
wait does that say 2 dollars for one little plug how much is shipping on that??
John Joedicke /
Tape over the hole!
how big is the hole use a pencil eraser damn
charles griffin /
there #9 ink caps for tattoing
You can get them at a hardware store but they may be black or chrome and not red.
Brian Carver /
you went to a hardware store and asked for the little red plugs for moped brakes? they probably thought you were nuts!
Ink caps
here buy these then sell the rest for a buck fifty and use the 50 cents for stamp and envelope so you will make a buck on each cap
I bet I could make a fabulous one out of FIMO.
What is there purpose? Have to do a tire,check brakes,and
Repack bearings while I'm there.
Thank you.
Ha! Look Ma! I took a picture 😁.
I took a picture!
I got some from sundaymorningmotors
It's there so you can check your shoes for wear without removing the wheel. That's all.
I have a bag of them from handy bikes
careful, if your looking for those red caps then your treading on thin ice
bairdco TU, question answered,
ggspeed, thin ice?
I assume you're talking about NO shoes are
left in the brake drum?
> I took a picture!
theres a fine line between "normalcy" and moped madness, yes little red dots gotta have it polka dots drive me crazy.
Caplug.
