i was down trying to work on the motobecane 50L (finally had time)... it doesnt spark. so i took the flywheel cover off so i could see the points as i was cranking (and was going to clean and set them).. then i noticed that they arent opening and closing as they should... when i pedal, the enging will chug intermittenly, but only seems to "catch" sometimes.. when it does, the points will jerk closed or open, but they dont move smoothly or with any sort of fluidity (or pattern)..
...could this be a clutch issue?
thanks!
casey
