Thanks for the reply.
Not sure if the plug is from the manual specs, or gapped right
It doesn't matter if it warm or cold. It will start right up after it runs, but if I wait more than even 10 or fifteen minutes, same problem.
Is there an adjustment on the carb for gas/air or only the idle screw and the bowl drain.
Thanks again for your help.
