I am looking for the jet inside my carb, I need to get a bigger one or drill the holes bigger because my motor's running too lean...
I took a photo of the brass do-hicky I pulled out of the carb... is this thing the jet ?
it says 52 Pacco on the end...
the end has a small pinhole..
there are 3 more pinholes on one side of the tube and two holes on the other side...
If this is the jet Im going to try and get a bigger one...
If I can't find a jet for this Pacco carb I might have to drill out the holes alittle...
If I have to drill it out, which holes would I drill ? The one pinhole on the end of this piece, or the 5 pinholes on the side of the tube ? Or do you drill out all the holes alittle ?
thanks again
Jimmy
