try squirting a little gas into the carb.... then try starting it.... if it fires and runs for a few seconds then dies then its a fuel problem...........remove the carb........ remove the floatbowl off the carb........... take out the brass jets and make sure you can see thru them.... also pull the gas line off the carb and turn on the gas to see if fuel is flowing to the carb.
