Better or worst?
this may sound stupid but i was just wondering, my friend changed his base gasket in the summer from a thin one which leaked to a new one made from cork which is alot thicker and i was wondering if it would affect its power since the ports would be opening earlier in the stroke
thanks Del
P.S. it is a Batavus Bingo
Worse
Reeperette /
The Cork won't last, hasta be aluminum.
Thicker = Less Compression, Less power.
Running too thin may endanger moving parts, however.
-R
Re: Better or worst?
Ree,did you catch that they were talkin' about the BASE gasket?I used regular composite material on my Franco-Morini (like car thermostat material)and it works good.
Re: Better or worse ?
A thicker BASE gasket means...
... a little LESS low end (because of a little less compression)
... but a little MORE top end (exhaust and transfer port timing duration is longer).
Most base gaskets are made of a cardboard type material.
(and a base gasket made from a 'cereal box'... say... will work OK in many cases... but I coat them with grease and let the grease soak in for a while).
I would think Cork is too soft and would squash too much.
Reeperette /
>>Ree,did you catch that they were talkin' about the BASE gasket?<<
D'oh...that advice bein meant for the HEAD gasket - my bad.
-R
If he was to leave the cork for more top end, but then shave the head down for more compresssion would it be just a goos as shaving head and replacing base gasket with cardboard?
Del
