Is it possible?
John Haberkorn /
Is it possible to install a starter on a moped like is found on a lawn mower?
Re: Is it possible?
like a pull chord?
Re: Is it possible?
I'm thinking you probably mean like an electric start...pushbutton or key operated? It would require a battery and some type of starter that would disengage when the engine started. I sure don't know enough about it to say but surely there would be something available or easy enough to retrofit.
Re: Is it possible?
You may be able to adapt one from a scooter, but you'd have a lot of fabricating to do.
I'm just wondering why nobody has done a do it yourself turn signal kit for mopeds. isn't it just a switch, battery, flasher, and lights? It shouldn't be too hard, right?
Re: Is it possible?
I mean a pull chord starter.
Try a motorcycle store for a turn signal kit.
Yep
Reeperette /
Yes.
I have seen it done on an old Tomos Bullet.
An older fellow I knew didn't have the leg strength and speed to kickstart it, due to arthritis, and his son somehow mounted the recoil-cord starter from a lawnmower, I believe.
Couldn't tell ya how they did it, right offhand, since I didn't get to watch him rig that, but yes - it is possible, and according to the son, not even all that difficult, at least on a Tomos.
-R
