worth buying?
PIGGIO MOTOR SCOOTERS,
2, not running for 25 years, $300 or best offer
Re: worth buying?
Ron Brown /
Don,
Unless they are rust buckets, absolutely.
Ron
Re: worth buying?
25 years??? Wow..... long time. Mine sat since '85 and here's what all I had to do to it....
New petcock.
New fuel lines
soak cables in ATF for about 3 days to break free, even then, two were still frozen.
New air filter
New tubes and tires
Muratic Acid for the fuel tank (then Kreem liner if needed)
New inline fuel filter so you can see if you got all the crud out of the tank when you do the above step.
New carb rebuild kit.
New light bulbs.
New battery
New Seat cover
New spark plug
Engine flush for the transmission, once you get it going.
New trans. fluids, changed about 4 times once running to clean out
New electrical parts (CDI for me) You might need new points/condensor/etc. etc.
LOTS of sandpaper
Paint
Easy out for screws that you will strip out when you try and take things apart
About 3 cans of WD-40 with straw.
Repack all bearings with good grease (HIGHLY recommend Mercruiser Grease)
New break shoes
Have to have the drums turned for brakes
Don't get discouraged here, but it CAN be done. Maybe you can do like I did. I actually had two QT50's. Figured out what worked on what, then picked the one wih the best paint, and combined the two of them. Have one working really well, the other, strictly for parts. You never know when you'll need parts. Things break or disappear.
Going to take a lot of time, but it will be fun.
Re: worth buying?
depends on what they look like but for the most part I'd say" oh hell yeah" ... are they 125's, and if their both all there can I get one of them??
