25 moby
Nathaniel Almeida /
Hey, my friend has the 25mph 50v. We switched out the gurtner with a 14 14 sha but it's still very slow. I was wondering if the 25mph edition has a restricted exhaust and if it can be derestricted. Thanks!
Re: 25 moby
Andrew Squiggman /
new belt?
Re: 25 moby
Nathaniel Almeida /
Its a brand new belt and it doesn't slip.
Re: 25 moby
Check your timing.
Re: 25 moby
Nathaniel Almeida /
ya it almost seems to backfire a bit when it starts so i think it could be the timing
Re: 25 moby
Stefan Didizian /
if its a horshoe exhaust, you can remove the end cap and open up the holes in the exhaust. it will help a little... check ur timing and get a new rear sprocket and a variator.
Re: 25 moby
www.mabecanemobylette.com explains the differences in 20, 25 and 30mph models. Restriction is done via port size, and carb/intake type, there are a. b and c jugs. As long as exhaust is not plugged up it should not be an issue.
Re: 25 moby
Yeah, what Stephen said. Adding a larger carburetor to the 25mph cylinder wont do much, due to the sizes of the ports. You need to open up the port windows to let it breathe better. Stock exhaust is fine. There is no restrictor. Check the wiki for info on how to port it. Also make sure the existing exhaust isn't clogged.
Re: 25 moby
Nathaniel Almeida /
ya ill see if i can find a port map for it. thanks!
