did i cut too much?
Salsa Salsa /
is there anyway i can fix this? nothing mounts up anymore. can i still run a e50 with just two holes?
Re: did i cut too much?
YOU BLEW IT!!!!!1!
Weird! ! Where is the axle gonna mount? ! Tehe
Hella Dankmeme, III /
JB Weld and zip ties should do it.
totally.... one less maxi n in this world... you will have to weld lots back on... and if you are planning on making this bike a ripper then you will NEED all three mounting holes for your engine... only two and that thing with twist the hell out of that frame and most likely break out of the two holes... no bueno. ;[
Maize, you suck at life!
derek from black pipes moped gang 🌧 /
I like where this is going.
What the hell are you gonna do on the rear end ???
Maybe get a new frame and quit cutting too deep. Or just weld plates to it... however ya wanna keep uglying it up is up to you. hahaa
Salsa Salsa /
corn OP
I dont know what i am going to do :( i couldn't see when i used the plasma cutter and lost control.
N destroyer!!!!
Damnit man
Aaron Bajongus /
metal can go back together.
its not ruined.
I call shenanigans...
hahahahahahahah maize
Looks good... less weight will help you go faster.
lol
A55 powered hub-less wheels project maxi N?
Ill give you $20 shipped for it. Do it.
Just uncut it.
control + Z
Salsa Salsa /
corn OP
Come on. I could ebay it for 300!
On the plus side it give you the opportunity to box and reinforce that weak little frame before you put some real power on it.
this frame has been rendered worthless due to some negligent workmanship. i'm not exactly sure what you were trying to do. i'm only certain in what you actually succeeded in doing.
300 dollars seems to be the going price for a maxi N frame. i've seen them go for that painted or powdered on here. i saw a complete non-op minus the engine go for that.
however, what you have is a worthless hunk of metal. you should sell it to the guy for 20 dollars. he is being generous. that POS that you created will take a bit of work to get right.
..... Anhersnus /
Wow man...ever think he might be stretching the frame? or do something else custom? You think this guy welded in a sick cross bar then accidentally cut off his drop outs? get real man.
kevin you are gonna eat your shit so fast. i cant wait.
Salsa Salsa /
corn OP
Eh maybe ill put a lifan 140cc scooter engine on. . .
i want to see what this thing looks like when you are done yankin' everyone's chain here and finish it.
I wish I had the kind of tools to fuck up a frame that bad before I knew what I did. Plasma cutters are expensive :(
trolls.
Vespa rear wheel for variation?
